Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-14-2010, 06:15 PM
yungblood is on a distinguished road
Need a PCB with fine traces milled/made.
First, here's the basics of what I need:
Double-sided PCB 8x12 (possibly smaller) with traces milled, and holes drilled out. Quantity 2.
I would like a rough quote for work done. Also if you provide the board, how much for the boards?
Now, for my other questions. Since this is the first time I'm asking for CNC work... What file format is needed to make this as easy as possible? And what program is recommended? I have autocad 2000. I can export anything to pdf.
This is to run the CNC machine I'm building.
Old 05-15-2010, 06:35 AM
Runner4404spd is on a distinguished road
if you want someone to machine it for you, then you need to provide a dxf of your traces you want milled. basically you will need to draw them up completely, not just a line drawing. you need the exact widths of the traces, both sides and all the hole locations and what sizes. i have made custom pcbs before but they were always single sided. double sided isn't that big of a deal but you need to be really careful on how you set up the second side.
Old 05-15-2010, 05:54 PM
Would it be possible to see a sample dxf file for milling a PCB?
Old 05-15-2010, 06:09 PM
mcphill is on a distinguished road
Go here: http://www.cadsoft.de/ and start learning...
Tags
drill, mill, pcb, qfw
pcb-gcode. how to remove all copper other then traces disonance PCB milling 7 06-03-2009 08:30 PM
First milled PCB Jason Marsha PCB milling 36 11-18-2008 08:49 PM
I need some slots milled in some 14 ga SS. Jeff Wohlt Employment Opportunity 2 10-31-2007 05:02 PM
Made in Australia (Made in taiwan, china) carbidecraters General Metalwork Discussion 0 01-10-2006 02:05 PM
Home made CNC mill (and some products made by it) gcamlibel DIY-CNC Router Table Machines 23 04-05-2004 05:54 PM
