Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-04-2010, 11:39 PM
diyengineer's Avatar
diyengineer is on a distinguished road
Talking RFQ Need bolt pattern machined in cast aluminum carriage.
Piece #1: Carriage off my gantry that needs the Z axis bolted to. Pictures 2-10 show the carriage. The piece is cast aluminum and is all one piece.
Picture number 7, clearly shows the face that the new actuator must bolt to. Picture number 6, displays dimensions of overall unit. (it may be hard to fit in a mill, since its large, and a weird shape)
Picture number 1 shows the gantry, the carriage goes underneath the gantry exposing only the face that the Z axis will bolt to.
Piece #2: 8" K2 z axis actuator.
Picture 11 and 12 show the new actuator (my z axis).
Picture 13 shows all the information that is required to machine the carriage so i can bolt the new Z axis on.
The Z axis is arriving sometime around the 10th, then i will have more pictures on exactly how i want them to go together. Just center the new axis on the plate. I will have to see if i want both bottom edges flush or if any offset will have to occur. I will for sure take pictures of them double sided taped together just to so everyone can get the picture on how it goes together properly.
I will not be sending the new K2 Z axis in the mail. If you are local i can drop it off to you, but you shouldn't need it with the full drawings supplied to you. I will be bolting the unit together myself.
If you have any questions please feel free to ask me.
Thank you!! =)
ID:	106474   Click image for larger version
ID:	106475   Click image for larger version
ID:	106476   Click image for larger version
ID:	106478   Click image for larger version
ID:	106479   Click image for larger version
ID:	106480   Click image for larger version
ID:	106482   Click image for larger version
ID:	106483   Click image for larger version
ID:	106484   Click image for larger version
Old 05-05-2010, 03:48 PM
http://www.cnczone.com/forums/showthread.php?t=103291
The link above is to my build thread, if anyone cares to look at the progress I've made, or just wants to know what it looks like.
Hopefully this piece will get me up and going!
slowly but surely!
Old 05-14-2010, 02:31 PM
Talking Update. Need done asap.
Here is the new Z axis. I basically need the bolt pattern from the Z axis drilled and tapped into the cast aluminum beige piece. Then i will be able to bolt the 2 together.
Hope that helps and gives some clarity to what i want.
As seen in the second picture, the Z axis actuator is centered in the middle of the beige plate, allowing access to the large and small black circles to the left and the right of it on the beige plate.
Thanks please message me, will box up and ship off asap!
ID:	107177   Click image for larger version
ID:	107178   Click image for larger version
ID:	107179   Click image for larger version
Old 05-15-2010, 02:27 AM
http://cnczone.com/forums/attachment...6&d=1273033290
Link above is the the Engineering drawings.
I also attached a picture in the first post.
Old 05-15-2010, 01:51 PM
Sorry for the confusion. I dont need ALL the holes drilled and tapped. I think 8 holes would be more than enough? (or more?) As far as what 8 holes to drill and tap is up to your best judgement. I need that thing to stay on there solid, like white on rice!
Old 05-19-2010, 12:49 PM
Work has been sent off to Montana. Thanks to all that inquired.
Bolt hole pattern for Fanuc 18i J.D.R General Metalwork Discussion 1 01-31-2009 04:33 PM
programming bolt hole pattern jrogus CNC Machining Centers 1 05-23-2008 01:23 PM
Circle With Bolt hole Pattern JJsFab Torchmate 5 03-10-2008 08:28 PM
Lining up a CNC mill to an existing bolt pattern? youngfg General Metalwork Discussion 8 11-07-2005 02:05 PM
200oz in Motor Bolt Pattern jhwatts Hobbycnc (Products) 4 10-13-2005 09:40 AM
