Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 04-13-2010, 08:25 PM
ferrous is on a distinguished road
wood routing
Laser or other. Small runs, mostly one-offs.
I am an artist looking to cut about 2 months of work off my pieces.. .I send you the file, and you router it... pretty simple, I think. I'm in Calgary Alberta, so the closer, the better.
Most of the pieces I need cut are 6" or under and distributed rather closely on an 8x4' sheet. I've never used more than a sheet at a time.. yet. It would be pretty easy to rearrange the bits to fit on whatever size your table takes.
I've been cutting them out with a band-saw and scroll-saw, then filing inside corners and wiggly spots with rifling files and hand sanding. Thing is, I already design them on the computer, for the most part, and I've been using glued down banner printouts as templates.
Yes, I know. I'm a primitive. But I'd like to skip most of the hard part and maybe start making a profit, you know? Or be able to put more time and energy into finish, perhaps.
If you can help, get back to me, I've got some files we could try out to start with. Work-trades are good too, as I can do small welding jobs and cabinet makery in my shop.
Old 04-14-2010, 08:31 AM
CarbonKevin is on a distinguished road
Sent you a PM...
Old 04-14-2010, 09:43 AM
AccurateCNC is on a distinguished road
We can help you with that! I sent you a PM.
thanks, kevin@acncs.com
Don Stinson Accurate CNC Services (208) 772-0641
don@acncs.com www.acncs.com
Old 04-16-2010, 07:28 PM
universalfab is on a distinguished road
Show us a example of how detailed your artwork is and then we all can give you a more educated quote. Thanks
Hard and Exotic wood routing? Crushmonkey WoodWorking 14 03-06-2012 05:12 PM
looking for a wood routing mentor ronateah Mentors & Apprentice Locator 0 06-08-2009 10:45 AM
Wood Inlay Routing - Near Cincinnati if possible bmsgaffer86 Employment Opportunity 0 12-01-2007 07:18 PM
RFQ Wood Engraving / Routing (poplar) danieljay Employment Opportunity 7 11-17-2007 11:08 AM
3d wood routing... Clan CNC Machining Centers 26 09-06-2004 04:34 PM
