Results 1 to 2 of 2
Thread: turning work
    Jan 2008
    turning work
    I need a quote on the attached print; quantity is 200 pieces and must be made to print, including plating. Can use 12L14 as a substitute for 12L15. Last run made for us had a burr inside the threaded hole from turning the chamfer after threading; which ever way you produce this, our QA crew must be able to use the thread gages in both ends of the threaded hole. Only USA shops need to quote, so no Mr. Wang or Fong or ??? Once I get the quotes, all in by 4/13, I will submit the quote for the assembly we are quoting for our customer and go from there. PM or email quotes to: greg@kernenconstruction.com and please do not post your prices here.
    Attached Thumbnails Attached Thumbnails turning work-1030006_b_sub.pdf
    Jan 2008
    RFQ closed
  1. Just IN- CNC vert. mill and turning center looking for work
    By OZZCAR in forum Employment Opportunity
    Last Post: 09-22-2008, 04:09 PM
  2. Newbie- Work Planes / Work Coordinates
    By MICFDI in forum Esprit
    Last Post: 05-12-2008, 12:35 AM
  3. RFQ: 4130 turning work
    By stanglou in forum Employment Opportunity
    Last Post: 01-20-2008, 11:15 AM
  4. Turning
    By camtd in forum SolidCam
    Last Post: 08-01-2007, 01:40 PM
  5. RFQ - Smallish turning work
    By Professorwiz in forum Employment Opportunity
    Last Post: 11-16-2005, 11:34 AM
