Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 03-14-2010, 08:03 PM
Teyber12's Avatar
Teyber12 is on a distinguished road
need some copper parts cut..
hey all!
Until i get a lot of stars alligned (probably early june) i really need some of these made for me until i can start making them myself. I would order 5-10 depending on the price.
The goal here is cost... low as possible. I have the copper i could ship to you.. i could modify the design quite a bit... the tolerances don't have to be perfect (the only real dimension that is important is the 1.375" OD shaft on the copper, because it has to mate with a copper cap). the rest could be +-.005" or so, maybe a little worse but should be better then +-.01".
here is another picture of it to give you a "what it looks like" view,
Hopefully i can find someone with a cnc lathe who is looking to make a little bit of money...
Cheers fellas.
Old 03-14-2010, 09:18 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Have you turned the alloy of copper you're considering? Copper is generally very gummy and does not like to be cut unless the tooling is very sharp. With those deep grooves, that means it needs to be a wider faced, grooving tool. Those parts will be more of a challenge than you might think at first.
Just a suggestion in case you can reconsider your design. If not, it is what it is and somebody will have to deal with it.
Greg
Old 03-14-2010, 09:28 PM
Teyber12's Avatar
hey mate!
I have machined a lot of these and yes its a bit of a PITA. I have changed the design to something easier to machine but my customers tell me this is the best design they have ever come across.
I have been machining these for a while on my x3 but im having some coolant problems and motor stalling problems while machining them (with a slitting saw).
the design could be changed so that the center post is .875", which would mean that the depth of cut(of the radius) would be .25".
To estimate the price, you can buy a similar one new for $45. Not including the price of metal(i would supply that) i was hoping around $25 a unit for 10 units. If this is too low it would be better for me to just make them myself.
cheers
Old 03-14-2010, 09:50 PM
larry53 is on a distinguished road
Would that be 2.50 each for a total of 10 parts, or do you mean 25.00 each for a total of 10 parts?
Old 03-27-2010, 01:13 PM
JPROCT is on a distinguished road
Have you found someone to do these yet?
Need Help!- Machining copper erkiwi General Metalwork Discussion 6 06-23-2008 04:24 PM
copper? bowhunter General Metalwork Discussion 13 04-26-2007 12:41 PM
Copper Vs Carbon JIMMY General Material Machining Solutions 9 10-25-2006 07:46 PM
beryllium copper trangt143 Haas Mills 12 02-02-2006 08:16 PM
what tip to use for copper? HawainPand General Metalwork Discussion 1 09-22-2004 03:30 AM
