Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-25-2010, 06:57 AM
NYCDragracer is on a distinguished road
I need a small job done
First off, Im located in the NY area of the USA, so I am looking for someone willing to help out and get paid well for the work in question.
I have a small 2 stroke motor I would like to apply a special ignition system too.
In order for this to work, some machine work maybe needed, but from looking at it, I think just a nicely designed mounting plate would do.
Anyone in the USA NY area, interested in seeing some pictures first, please contact me back.
Thank you very much
Old 02-25-2010, 09:06 AM
Cruiser is on a distinguished road
Are you converting alcohol to gas or getting rid of a magneto ? and what eng ? You must be mounting a hall effect electronic ig, I've done a few for myself.
Don
IH v-3 early model owner
Old 02-25-2010, 09:12 AM
Ultdcreations is on a distinguished road
Machined Parts
Hello,
My name is Nate Heinze and I am the owner of a small machine shop in Louisville, Ky. I think I can help you with the parts you need at a decent price. Please give me a call or write if your interested. Visit my website at UnlimitedCreationsLLC.com.
Thank You,
Nate
Old 02-25-2010, 02:13 PM
As you can see in the pictures, this is a small 2 stroke motor made from billet aluminum.
I have a special ignition system I need to bolt to the motor, from what I can see, I need a plate made up to bolt to the crank case shown in the first picture, then after the plate is mounted, set the magnate on the crank shown in 2nd pic, we usually use a business card to get the proper gap from the coil, so by doing this and then sliding the coil on, center it to the stem of the crank, drill and tap 2 mounting holes to match the coil and WAALAA!
The coil need to be mounted in the position shown in my picture, it will later on have some adjustment for retard and advancement.
Sounds easy, I know....Anyone in the NY,NJ area?? I do not want to ship this anywhere, sorry.
ID:	100745   Click image for larger version
ID:	100746   Click image for larger version
ID:	100747   Click image for larger version
Old 02-26-2010, 09:36 PM
Job is done, find a great guy local, just wanted everyone to know, if you need someone in the NY area here he is: http://www.ishprecisionmachine.com/index.html
Tell them I sent ya!
Measuring small angles on small workpieces. skiingman Calibration & Measurement 1 04-01-2009 07:40 PM
Need Help!- Which small cnc mil cdfracing General Metal Working Machines 1 09-10-2008 06:06 PM
Need Help!- We need small CNC mpopov Want To Buy...Need help! 9 07-06-2008 12:33 PM
The bit is HOW small? Rhodan General Electronics Discussion 0 12-05-2007 10:59 PM
