Plastic Fabricator with CNC Router/Saw knowledge with some programming (doesn’t need to be at Engineer level) to write programs for new parts. As well as modify existing program when needed.
Experienced with CAD CAM software
Experienced with G code
Blue Print Reading
General Machining Knowledge
Warehouse Experience
Ability to quote accurate lead time to provide parts.
Computer literate (meaning other than programming – being able to use Office, Outlook other programs etc.)
Someone having the below experience could also work:
Wood Working Experience
Metal Machining Experience
Programming is an important role we need to fill but it’s not the lion’s share of the responsibilities.
Do you accept applicants outside the US? I think I met all your desired qualifications and much more than that actually. Im more than willing to be tested here, send me some sample products then I give you the pictures of the finish product. big or small, metal to wood. custom CAM or auto CAM, but I prefer custom CAM, it`s very efficient in terms of material and time, it cuts straight to the point so I can nest it as close as 1mm.
Side note: I can settle for a minimum wage in your country. been there for 7 years but on a different field of work. my edge is the ability to repair any CNC unit (Router, Plasma, Laser, Galvo) from a simple electrical all the way down to the board itself.
