For over 43 years, D&D Machine Works has been a leading machining solutions center based in Lethbridge, Alberta. Servicing a range of customers in the agriculture, food processing, transportation, oil and gas, earth moving and primary manufacturing industries, we are experts in custom CNC machining, manual machining, manufacturing hydraulic cylinders, welding, and fabrication.
D&D Machine Works is currently seeking an experienced Manual Machinist to join our team in Lethbridge, Alberta on a full-time basis.
This is a great opportunity for a skilled Journeyman with extensive conventional machining experience to work on challenging and varied projects.
Capable of working from shop drawings within close tolerances, you will also demonstrate proficiency with:
  • Engine lathes ranging in size from 20" to 48" swing
  • Milling machines
  • Associated machine shop equipment
All employees receive a competitive wage, based on your experience, skills, and qualifications. You will also receive access to a comprehensive benefits package after six months.
Don't miss this opportunity to join an innovative, fast-paced and supportive team. Apply online today at www.applyfirst.ca/job88435
