Career Opportunity: Machine Builder (2nd Shift) with Cincinnati Incorporated - Harrison, OH
Do you love working with your hands, building things? Are you proud when the final product comes together and is completed? Do you enjoy working in a positive, energetic team environment? If so, we want you to join our team!
Cincinnati Incorporated is a national machine tool manufacturer with worldwide recognition. We are one of a handful of U.S.-based, build-to-order machine tool manufacturers, and have shipped more than 50,000 machines in over 100 years of operation. From our modern 500,000-square-foot plant and technical center on an 80 acre campus near Cincinnati, Ohio, we engineer and build our machines to the standard of ruggedness required in the North American market – with premium engineering features that stand up to years of rigorous use in demanding environments. Our machines' endurance is legendary. It is common to see Depression-era CINCINNATI press brakes and shears in daily use today.
We are looking for the right people to join our organization. Our core values drive our everyday interactions with the common goal of shipping high quality products to our customers (About Us — Cincinnati Incorporated). If you share these values, we want to meet you.
We are looking for a Machine Builder to join our 2nd Shift manufacturing team. The successful individual will align, fit, and install structural component parts used in the initial and final assembly of mechanical and hydraulic products. This position will be responsible for the following activities:
• Align, fit, and install structural components (housings, cross members, squaring arms, slides, etc.);
• Move parts around work area with cab or floor operated cranes, using ropes, chains, and lifters;
• Lay out work for welder as required;
• Drill, ream, pin and tap holes, as required for assembly;
• File and grind surfaces for proper fit;
• Remove burrs and chips before assembling;
• Mount bolts, studs, blocks, connecting rods, guides, brackets, motors, brakes, flywheels, angle brackets, pumps, valves, gibs and ways, oil lines, back gauges, etc.
• Check fit for alignment and parallel to ensure smooth operation of moving parts and adjust as needed for proper clearance and function.
Required Qualifications:
• High School Diploma
• Associates or technical school degree, preferred
• 3+ years previous mechanical hands on experience, preferably with machine building
• Ability to read and interpret complicated blueprints, drawings, and schematics
• Excellent math skills
