Career Opportunity: Electrical Assembler (2nd Shift) with Cincinnati Incorporated - Harrison, OH
Do you thrive on bringing life to a machine? Do you have a passion for seeing projects through to completion? Do you enjoy working in a positive, energetic team environment? If so, we want you to join our team!
Cincinnati Incorporated is a national machine tool manufacturer with worldwide recognition. We are one of a handful of U.S.-based, build-to-order machine tool manufacturers, and have shipped more than 50,000 machines in over 100 years of operation. From our modern 500,000-square-foot plant and technical center on an 80 acre campus near Cincinnati, Ohio, we engineer and build our machines to the standard of ruggedness required in the North American market – with premium engineering features that stand up to years of rigorous use in demanding environments. Our machines' endurance is legendary. It is common to see Depression-era CINCINNATI press brakes and shears in daily use today.
We are looking for the right people to join our organization. Our core values drive our everyday interactions with the common goal of shipping high quality products to our customers (About Us — Cincinnati Incorporated). If you share these values, we want to meet you.
We are looking for an Electrical Assembler to join our 2nd Shift manufacturing team. The successful individual will perform wiring and testing of circuits and electrical equipment on all products. This position will be responsible for the following activities:
• Lays out, cuts, bends, threads, assembles and installs conduit as required.
• Drills, reams and taps holes to obtain means for fastening pipe, fixtures, etc.
• Positions and mounts electrical equipment, fixtures, cabinets, pipe braces stands, etc., to products manually or using overhead crane as required.
• Works from schematic drawings, wiring diagrams and own judgement.
• Lays out, measures and cuts wires and cables to required lengths.
• Runs wire through conduits and makes all necessary connections to motors, generators, control panels, fixtures, switches, etc; to complete circuits as specified.
• Skins wires and crimps and solders, terminal to ends; cables and wires as necessary for safety and appearance; attaches identification tags as required.
• Tests operation of all electrical devices such as relays, contacts, controls, etc.
• Tests wiring and operation of electrical equipment, taking necessary readings of speeds, diagnosing troubles and making necessary adjustments as required.
• Works with high and low voltage current; keeps records of material specifications to facilitate work, wires and checks as required.
Required Qualifications:
• Associates degree in Electronics or Electrical Engineering Technology
• 3+ years previous Electrical/Electronics assembly work experience
• Ability to read and interpret complicated wiring diagrams and schematics
• Excellent math skills
