Career Opportunity: Grinder Operator (2nd Shift) with Cincinnati Incorporated -Harrison, OH
Do you excel at circular grinding operations? Can you operate both CNC and manual grinding machines? Do you enjoy working in a positive, energetic team environment? If so, we want you to join our team!
Cincinnati Incorporated is a national machine tool manufacturer with worldwide recognition. We are one of a handful of U.S.-based, build-to-order machine tool manufacturers, and have shipped more than 50,000 machines in over 100 years of operation. From our modern 500,000-square-foot plant and technical center on an 80 acre campus near Cincinnati, Ohio, we engineer and build our machines to the standard of ruggedness required in the North American market – with premium engineering features that stand up to years of rigorous use in demanding environments. Our machines' endurance is legendary. It is common to see Depression-era CINCINNATI press brakes and shears in daily use today.
We are looking for the right people to join our organization. Our core values drive our everyday interactions with the common goal of shipping high quality products to our customers (About Us — Cincinnati Incorporated). If you share these values, we want to meet you.
We are looking for a Grinder Operator to join our 2nd Shift manufacturing team. The successful individual will perform machine setup and operation. This position will also be responsible for the following activities:
• Perform circular grinding operations with both CNC and manual operation machines;
• Setup and operate machines to perform machining operations;
• Read drawings and setup sketches to accurately machine parts;
• Edit CNC programs as needed to ensure accuracy to drawings;
• Inspect parts after each machining operation using bore gauges, micrometers, or probes;
• Perform extremely close tolerance grinding and polishing operations on various size and type shafts, pistons, brake drums, plungers, toggles, gears, and similar parts; and
• Maintains a clean and orderly work area.
Required Qualifications:
• High School Diploma or equivalent
• Technical school certificate, preferred
• 2+ years previous machining experience
• Ability to read and interpret blue prints, drawings, and machine sketches
• Geometric Dimensioning & Tolerancing (GD&T) skills are required
• Ability to edit G-code programs for CNC machines, preferred
