Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EMCO CNC machines > Emco Mills
Old 10-17-2009, 11:55 PM
oxford's Avatar
oxford is on a distinguished road
Need help with collet size: PC Mill -30
I want to take my milling to the next step and realize I need some collets to do this.
Right now I am using a small piece of drilled out and tapped aluminum bar stock to hold my end mills.
Sometimes it works....sometimes it is ugly.
The only info I found was from a NZ selling a similar model who said the collets have a 10mm OD.
Anyone know what kind of collets to use?....or
Are there measurements I could take of the inside of the spindle where the collet fits in to find out if there is standard type of collet to buy?
Old 03-20-2010, 12:16 AM
oxford's Avatar
Here is a crude cross-section of where the collet would fit in.
Maybe the included numbers may jog somone's memory about familiar collet sizes.
....I hope.
Thanks for looking
Old 04-11-2010, 10:41 PM
oxford's Avatar
ER11
I finally ponied up $25 for some an ER11 set. They fit nicely. Now I just need to test their runout.
ER16 Collet Size Problems Bob La Londe General Metal Working Machines 23 02-08-2012 12:24 PM
Wrong collet size with Chinese spindle George General Electronics Discussion 4 09-24-2011 09:40 AM
What is the maximum collet size for your CNC router? widgitmaster Polls 2 12-30-2008 11:14 PM
Collet type & Alu mill cutters fotiosanagnosto General Metalwork Discussion 0 05-19-2007 02:45 PM
What is this collet size? kong General Metal Working Machines 2 06-06-2004 02:07 PM
