Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EMCO CNC machines > Emco Mills
Old 08-16-2011, 05:22 PM
João André is on a distinguished road
Question Our Emco Concept Mill 155 is stoppping between code lines?
So here it goes... one of these days when i turned the machine on the software was messed up and i could not operate the machine at all. The operator installed new software and the mill is back on but when he's doing a contour the end mill pauses for a split second in every code line change, witch is causing our parts to be have marks in the place were the tool stops.
We recently found out that if the program has no peck drills the this problem disappears and the contours are smooth Help any one? Thanks in advance.
Emco CNC Compact 5 or Concept PC Turn 55? fgc EMCO CNC machines 0 03-03-2011 01:27 AM
emco Concept MILL 300? byronk EMCO CNC machines 1 02-17-2011 04:04 AM
WTB Emco Concept Turn 55 crucialthreads Want To Buy...Need help! 0 10-18-2010 05:43 PM
Emco Concept 55 Lathe skinnekid EMCO CNC machines 2 04-15-2010 04:27 PM
Emco Concept turn 55? praetor Vertical Mill, Lathe Project Log 0 06-08-2008 12:18 AM
