Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EMCO CNC machines > Emco Mills
Old 12-12-2010, 05:42 AM
avayan is on a distinguished road
EMCO PC Mill 50
Hi Group,
I was lucky enough to get me a rather old but still "working" EMCO PC Mill 50 CNC machine. I say "working" because it is missing one of the modules (I believe) and of course I have no PC and no software whatsoever. So I thought about retrofitting it with my own electronics, but the motors are 5 phase steppers for which I have nothing.
Hence there are two options:
1. Try to find all the missing components (hardware or software)
or
2. Retrofit the machine with new steppers and new drivers.
Which one do you think will end up being easier? Is any documentation out there on this equipment? I can not find much and I already searched this forum. Thanks for any help you may provide!
Old 12-25-2010, 02:14 PM
kmckenn is on a distinguished road
Call EMCO (Columbus Ohio) and check on pricing of the required ISA PC Interface board for the 50 (I've heard the 50 and 55 cards are actually different). They are pricey ($600-$800??). If/once you have/get that (or not), you'd need the emulation software running on a Win98 PC. THAT is what it takes to run an EMCO "PC Mill" anything, besides the mill itself.
After that is taken into consideration, then you have a good idea what you are weighing it against in whatever conversion you might plan.
I have a PC Mill-55 and PC Turn-55, interface cards for each and software, so I can be some help/guidance in that regard.
Hope the information helps
Kevin
Help with Emco F1 mill svon89 Benchtop Machines 14 06-06-2010 04:54 AM
Need Help!- Emco PC mill 50 Madog-Mitchell Benchtop Machines 1 11-10-2009 05:34 AM
I need some help with an Emco PC Mill 125 Cinci_State_01 Benchtop Machines 2 05-05-2008 09:13 PM
Emco PC Mill 30 Questions lanb Benchtop Machines 1 09-24-2007 12:00 AM
Upgradeing a Emco F-1 cnc mill woodythx13 Benchtop Machines 1 10-01-2005 02:30 AM
