Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EMCO CNC machines > Emco Mills
Old 10-09-2010, 10:36 AM
sparkymike is on a distinguished road
Fi Mill Diskette operation
Hi. I have an F1 mill which is fiied with a diskette and not a cassette as shown in the handbook.
Which controls are used to get this to save/run/ etc?
Which codes need to be used for this device?
If this mill was fitted with this from new, does this mean that it is a late model Emco and can this be connected up for pc use?
One other point, the cross traverse (Z) works in the opposite direction to the diagram shown on the control board front. Any answers here? The X and Y modes are correct.
Thanks for any help here,
Mike.
Old 05-28-2011, 09:28 AM
Wouter_1992 is on a distinguished road
I think you should try the normal save/load G codes for tape use (I think G65 -> inp -> programnumber -> inp but don't know exactly anymore)
Also with every emco F1 your able to "connect" to a pc via RS232 (its just sending and receving programs so not realy connecting as controling it via the pc or anything)
Need Help!- Mitsubishi DWC Diskette problem jotadege General CNC (Mill and Lathe) Control Software (NC) 1 11-03-2010 11:37 AM
Need Help!- Hawk 5 Ultimax 3, upgrade to USB from 3.5" floppy diskette xtrmestylin HURCO 2 02-03-2010 06:28 PM
Can Okuma vmc 4020 load program from diskette? Taehk Okuma 22 08-11-2009 09:33 PM
operation camtd FeatureCAM CAD/CAM 1 11-28-2007 10:07 AM
102 Mis Operation mattme Mazak, Mitsubishi, Mazatrol 0 07-03-2007 11:48 AM
