Results 1 to 5 of 5
Thread: Weight of Emcoturn 140/240
    Dec 2009
    Does anyone have any literature that states the weight of an Emcoturn 240 Or the 140? Need actual numbers. Thanks
    Marty
    Jan 2005
    Marty_Escarcega
    Around 3400lbs + transformer & hydraulics if you have them
    Mactec54
    Dec 2009
    Marty_Escarcega
    How did you arrive at that number? We have a 7000lb capacity trailer and were planning on picking up the Emcoturn and a couple of Hardinge Chuckers. Just wanted to be sure we are good with the load.
    Thanks!
    Marty
    Jan 2005
    Marty_Escarcega
    Because I have one, & moved it my self, I found out the weight before I moved it from the spec of the machine, my trailer is only 5,000lbs rated & was no problem
    Mactec54
    Dec 2009
    Marty_Escarcega
    Thanks!
    1. Emcoturn E25
      By rayoung in forum EMCO Lathe
      Last Post: 11-29-2011, 12:52 PM
    2. EMCOTURN 342 help
      By dand0321 in forum EMCO Lathe
      Last Post: 08-31-2011, 09:43 AM
    3. Emcoturn 342
      By ratam in forum EMCO Lathe
      Last Post: 08-01-2011, 01:36 PM
    4. EMCOTURN 140
      By tpmx57 in forum EMCO CNC machines
      Last Post: 07-03-2010, 04:20 AM
    5. EMCOTURN
      By tpmx57 in forum General Metal Working Machines
      Last Post: 06-18-2009, 06:23 PM
