Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EMCO CNC machines > EMCO Lathe
Old 04-08-2011, 03:11 PM
abc27 is on a distinguished road
Concept Turn 55
Hey, i've recently discovered my school is in possession of one of these lathes. They appear to be rather good and I am starting to get to grips with the software interface but I am still having major issues trying to actually understand the workflow.
Say I have a DXF of a part I exported from Solidworks, how would I generate a toolpath from this DXF? The software seems really poor to be honest.
I am also having an issue with the tool changer. It's stuck on tool 0 when I enter NC mode in WinNC and when I try to manually change it to anything else using the software the machine makes a sound as if it's going to start moving but then doesn't actually do anything and just gives me a tool change timeout error.
So to sum up, how would I fix the tool change timeout error and how exactly do you generate toolpaths?
Extra information: I'm using the CAMConcept (WinNC) software that came with the machine and the machine itself is a late 2007 model that has seen no use whatsoever apparently and is connected to the PC via Ethernet.
Old 04-10-2011, 08:00 AM
Doesn't anyone know?
Old 04-10-2011, 10:10 AM
For example a problem I am having now. I am simply trying to program to turn a piece down to a certain diameter and I am getting a strange issue "4034 2: turning cycle diameter too big". I even get the same error if I try to reduce the diameter by 1mm.
Reading the manual that means I need to set a cutting depth but there is nowhere for me to define a cutting depth in the software. I also still have the issue with the toolchanger.
Emco CNC Compact 5 or Concept PC Turn 55? fgc EMCO CNC machines 0 03-03-2011 01:27 AM
My CNC Concept V8 BUG General Metal Working Machines 0 11-22-2010 08:28 PM
WTB Emco Concept Turn 55 crucialthreads Want To Buy...Need help! 0 10-18-2010 05:43 PM
Manufacturer of Concept 250 CNC turn jetblack750il Want To Buy...Need help! 0 06-13-2010 11:08 AM
Emco Concept turn 55? praetor Vertical Mill, Lathe Project Log 0 06-08-2008 12:18 AM
