Then it was time to produce one more tool for the revolver on my EMCO. I find it difficult to inner turning when I want to have small dimensions. I chose to make a mount that fits in EMCO's 16mm holder. The idea was to adjust the tool so it can carefully whether I want to run the M03 or the M04 1: A 16mm axis 16mm shaft turned down to 16x40mm + 12x35mm. 2: An eccentric 6mm holes inclined at ~ 5 degrees drilled straight through the milling machine. ![]() 3: Two holes for M5 screws stop production ![]() 4: Here you can see the stop screws and steel mounted. ![]() 5: The button side up. This hole was made in the mill. ![]() 6: This picture shows tool mounted in the revolver. The advantage of this tool is that I can I rotate the steel. and also the tool holder. This allows me to get all the settings. ![]() The last picture shows the tool holder, seen from behind. ![]() hope someone can benefit from my idea ![]() Difficult to read? I use English-Swedish translator |
| Emco PC turn 120 | spankyky | EMCO CNC machines | 1 | 06-25-2010 08:09 PM |
| Manufacture of tools for EMCO revolver | cnc_swe | Metal Working Tooling | 6 | 08-05-2009 01:12 PM |
| Manufacture of tools for EMCO revolver pc turn 120 | cnc_swe | EMCO Lathe | 0 | 08-05-2009 12:53 PM |
| Need Help!- Emco Turn 320 | J_Copeland | Want To Buy...Need help! | 0 | 10-21-2008 11:26 AM |
| Need CNC Machinists to manufacture our Portable Machine Tools for innovative uses! | CPMT-HR | Employment Opportunity | 0 | 03-22-2007 07:14 PM |
