Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EMCO CNC machines > EMCO Lathe
Old 08-10-2010, 05:31 PM
cnc_swe's Avatar
cnc_swe is on a distinguished road
Mount on a six-jaws chuck on my lathe
Hallo
I have an EMCO PC Turn 120 cnc as original is equipped with a 80mm chuck.
I'm interior dimensions too small and I chose to buy two new chucks. A 6 JAWS 100mm and
125mm with three jaws. Below, I show how I did to get the smaller chuck in place.
I am a happy man who is owner of several lathes, which makes the job easier
In my case it was chuck understand the back to fit between the old disc and the solution was
to produce a thin ring that fits into the outside respectively. 72.00 x 69.00 x 3.6mm
To the left, Chuck without holes and to the right the thin circle.
Here is the ring of the disc
and here I try the same ring on the back of the chuck.
-Splitting and cutting holes for 3pc of bolts.
- Cutting measure for the hexagonal bolt heads. 13.20mm
Finally, a question.
I see that many widely read but very few comments or questions.
If no one answers on the forum, it will die and become irrelevant.
I think that regardless of quality of the images, let us take some of your machines, tools, etc. or am I wrong?
Next project is a 125mm chuck in need of both the disc and balancing.
Old 08-10-2010, 06:04 PM
TOTALLYRC is on a distinguished road
Nice work.
Old 08-10-2010, 08:13 PM
cnc_swe's Avatar
Thank´s
Old 04-08-2011, 02:46 PM
rot rot is offline
rot is on a distinguished road
Hello,
for me, a Emco compact 6p owner its a very interesting thread. Clever made but i would be frightend ruining the chuck.
Greetings Rene
Old 04-17-2011, 04:33 PM
cnc_swe's Avatar
Hi Rene,
who do you not afraid to drill into the chuck but sometimes you have to gamble a bit.
Only one call to the TOS again and you have a new chuck for 3 days.
Simple and nice as snuff ;-)
Need Help!- Chuck & Jaws jdgromi General Metal Working Machines 3 01-29-2009 05:48 PM
Newbie. Need to make soft chuck jaws for Mori lathe bob1112 General Metal Working Machines 10 03-13-2008 08:07 PM
milling chuck jaws theatrewizard Haas Mills 4 02-28-2008 10:09 AM
CNC Lathe chuck with adjustable Jaws ? Larken General Metal Working Machines 4 02-03-2008 10:47 AM
truing lathe chuck jaws wrenchcruncher General Metal Working Machines 2 01-17-2007 12:03 PM
