Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EMCO CNC machines > EMCO Lathe
Old 07-10-2010, 05:23 PM
cnc_swe's Avatar
cnc_swe is on a distinguished road
Biggest chuck in pc turn 120
What is the biggest chuck you have an EMCO PC Turn 120.
Original is the only 80mm but in my machine, it was a 100mm.
I have now bought a 125mm chuck with 30mm internal diameter, but it weighs
4-5kg. Someone who knows what they dare to have. My new chuck is made of steel so the speed is no problem. 5500v (/ min
Old 08-10-2010, 07:27 PM
cnc_swe's Avatar
Perhaps no people have experimented, but I have done the following test.
125mm steel chuck is probably the largest you should install if you dare take the risk.
Instead of 4000 V / m is now up to 3000. If I run faster and reduce speed or stop by
aM05 machine stop running and an error message appears on the screen.
But the advantage of this chuck is that the inner hole of the chuck is 30mm, which is quite a bit.
It can be run with less load on the tool. I do not know if there is an overload or deceleration,
that is the problem. I let it be gone for a better assessment of someone else here on cnczone.
Do you have more experience on the impact of electronics on the machine or let use simple instructions
do not be shy, what do you think, the machine will burn? or the Perhaps no people have experimented, but I have done the following test.
do not be shy, what do you think, the machine will burn?Perhaps no people have experimented, but I have done the following test.
do not be shy, what do you think, the machine will burn? or the neighborhod may be energized in his apartment ;-)
Old 08-10-2010, 07:51 PM
cnc_swe's Avatar
I can´t find out how I can erase this post
Old 08-10-2010, 08:11 PM
cnc_swe's Avatar
1
Old 04-08-2011, 02:35 PM
rot rot is offline
rot is on a distinguished road
hello,
i dont think that you will burn the main drive. I think the mayor problem is the big possibility of crashing boring tools because of the big diameter. I checked this at my machine (compact 6P similar to 120 p) and when i was planning there was only 8mm space between the boring tool in the next position and the chuck. So at my machine more then a 100 dia chuck and it will come to a crash.
Greetings Rene
Old 04-09-2011, 08:23 PM
cnc_swe's Avatar
yes you are right but if I load the revolver so the longer the tools, at least one number in from or perhaps on the opposite side of revilvern, which decreases the risk more.
I'm very happy with the results.
Old 04-27-2012, 03:11 PM
rot rot is offline
Hello,
last week I´ve installed a 100mm 3 jaw chuck from Bison on my compact 6p cnc. I am much happier with the Bison. The 80 mm TOS chuck that i´ve installed 3 months before was not capable enough.
Greetings Rene
Old 04-27-2012, 04:02 PM
mactec54 is on a distinguished road
cnc_swe
You may have to put a bigger braking resistor to take the extra load when it is slowing down, or if you can find a deceleration parameter & increase the time that will do it as well
If you can't find anything slow the spindle by 1000RPM steps, that may work as well
Mactec54
Old 04-28-2012, 05:19 AM
cnc_swe's Avatar
That makes sense what you say. The question is just how I find the braking resistor.
I'll have an entry in each g-code where I straights 1000 turns and waiting a half or second before stopping.
S1000
G04 500
M05
Old 04-28-2012, 07:41 AM
cnc_swe
If you look in the cabinet in the bottom right hand side, down below the spindle drive, you will see a rectangle Gold in color with some fins on it, this may be under a orange perforated grill, this is the braking resistor, Just see if it is over heating,when you are stopping the spindle, if it is not then just do the ramp down in the program, or find the deceleration parameter & give it a longer time
Mactec54
Turn spindle chuck unclamped FUN4ME Haas Lathes 1 04-22-2010 01:36 PM
Easy Turn Chuck Handle on TL2 Geof Haas Lathes 5 09-30-2009 11:20 PM
Biggest end mill in aluminum? DeusExMachina Taig Mills & Lathes 15 05-01-2009 11:03 PM
The BIGGEST THK rails ever!!? DennisCNC Linear and Rotary Motion 22 03-15-2006 05:03 AM
