Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EMCO CNC machines
EMCO CNC machines Discuss EMCO CNC machines Here!
Old 11-30-2010, 01:38 PM
sebastian_dogar's Avatar
sebastian_dogar is on a distinguished road
Exclamation Constant surface speed on emco e-200
Hi everyone! I have an EMCO E-200 lathe and i've been working with it for two months now. The only thing that I haven't been able to undestand is how does the CSS work on this control. Normally, you would have to put the feed in m/ min and the software should calulate the speed knowing the diameter given. I f there is someone that knows how to set this right please give me a hint. Thanks.
Tags
constant surface speed, emco e-200, lathe
Newbie- Constant surface speed control sebastian_dogar General Metalwork Discussion 5 09-23-2010 08:39 AM
Constant Surface Speed w/RPM limit Joe Miranda Milltronics 2 08-13-2009 11:58 AM
Constant surface speed Bergen CNC Daewoo/Doosan 4 07-13-2008 02:10 PM
constant surface speed mr.mark General Metalwork Discussion 3 10-03-2007 02:21 PM
Constant Surface Speed raymond1 Bridgeport and Hardinge Mills 9 01-07-2007 10:17 PM
