- Need Help!- emco vmc 100
Re: emco vmc 100
No, The machine is already operating correctly; its a mental thing....
Re: emco vmc 100
well its kinda fixed and now i feel retarded........so the jog buttons in my opinion are still backwards but the machine does now move the right way and it does display the correct way .....the problem ....uhg ...when I got this the guy had a work offset programmed in and without using g53 to clear it I was always reading "from" him offset ....-48.00 mm then move 25.4 it still read a minus number ...duh ,,,,but thanks to all of you that helped after I cleared the work offset it reads right damn lol
Re: emco vmc 100
Are You still using this machine. I'm just starting totry to run this machine and i'm looking for info about alarm codes.
Maybe You have some more detailed trouble shooting manual.
I definitelly need to recover the parameters, but as far now i'm stuck with alarms at startup.
- You may not post replies
- You may not edit your posts
Forum Rules
