Need Help! emco vmc 100 - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: emco vmc 100
  1. #21
    Oct 2009
    Default Re: emco vmc 100
    No, The machine is already operating correctly; its a mental thing....
  2. #22
    Jan 2007
    well its kinda fixed and now i feel retarded........so the jog buttons in my opinion are still backwards but the machine does now move the right way and it does display the correct way .....the problem ....uhg ...when I got this the guy had a work offset programmed in and without using g53 to clear it I was always reading "from" him offset ....-48.00 mm then move 25.4 it still read a minus number ...duh ,,,,but thanks to all of you that helped after I cleared the work offset it reads right damn lol
  3. #23
    Mar 2016
    Poland
    Are You still using this machine. I'm just starting totry to run this machine and i'm looking for info about alarm codes.
    Maybe You have some more detailed trouble shooting manual.
    I definitelly need to recover the parameters, but as far now i'm stuck with alarms at startup.
emco vmc 100
emco vmc 100
