Need Help! Emco compact 5 PC stepper motor information
Results 1 to 2 of 2
Thread: Emco compact 5 PC stepper motor information
    Jul 2013
    Default Emco compact 5 PC stepper motor information
    Hello
    Recently i bought 2 of these machine with good price.
    the stepper was gone.
    So anyone here know the Current (A) and Voltage (V) of the original emco stepper motor???
    so i can replace it with the new one with the same spec.
    After search on google, i got 2 manual from emco compact 5 PC and CNC.
    step angle is 5 degree
    Voltage 10 v (still confuse for me, in the manual mention about 40V too)
    6 wire
    Hope i got answer from this forum. I got none answer from yahoo group of cnc emco.
    Best regards
    Attached Thumbnails Attached Thumbnails Emco compact 5 PC stepper motor information-33541911-emco-compact-5-cnc-maintenance-manual   Emco compact 5 PC stepper motor information-emco_compact_5-pdf
    Jan 2017
    Luxembourg
    Default Re: Emco compact 5 PC stepper motor information
    Hello
    You can only find this motors on ebay, look for "emco cnc" and you find some used motors but look if the pulleys are still in place.
    (Most people reuse the pulleys)
    Best would be to change to an new control an use 1.8 degree motors with better resolution.
    Dieter
