- Compact 5 overall dimensions?
What are the length, depth, height and weight of the various versions of the Compact 5 lathe?
I'm looking at a couple of them 1,500 miles away and need that info to get shipping quotes. One is a PC version that appears to have had a stepper and spindle motor upgrade but is missing the control cabinet so it's essentially the same dimensions as a standard manual version. The other is a manual version of the lathe.
Can't get shipping quotes without knowing exactly the size and weight. :P
Having the info for the manual, PC and CNC versions (posted in a sticky thread) would be beneficial to all who need to have these lathes shipped long distances.
I found a manual for the PC version which says the weight is 55 kilograms 121 pounds, overall length is 830 mm 32.7", depth is 620 mm 24.5". But that's with the base cabinet and control electronics. The manual neglects to tell how tall the thing is.
Re: Compact 5 overall dimensions?
Found an eBay auction for a manual Compact 5 in Canada with a photo of the specification page.
20 kilos (44.09 lbs), 760 mm (29.92") max length to end of tailstock handle with it all the way to the right, 410 mm (16.14") depth, 230 mm (9.05") height.
- You may not post replies
- You may not edit your posts
Forum Rules
