- Winnc Daughter card or not?
Hello,
I recently got an Emcoturn 325-II.
The pc was seperate from the machine when I bought it. I tried to put the pc in and hook up the cables but I have (1) Cable with no where to plug it in. The connector is about the size of a parallel port cable but it has 3 rows of pins.
Is there supposed to be a daughter card in the pc for this cable? I haven't powered the machine yet.
Thanks for any replies,
Eric
Re: Winnc Daughter card or not?
Yes, you must have a daughter card. Good luck. If you find one they are extremely overpriced.
James L
- You may not post replies
- You may not edit your posts
Forum Rules
