New Machine Build EMCO PC 105 PathPilot, iBOB2, Gizmosphere1, AC Servo Refit
Results 1 to 2 of 2
Thread: EMCO PC 105 PathPilot, iBOB2, Gizmosphere1, AC Servo Refit
    Member Iron-Man's Avatar
    Jan 2009
    Default EMCO PC 105 PathPilot, iBOB2, Gizmosphere1, AC Servo Refit
    I have been working on a PathPilot AC servo refit for Smokediver's Emco PC 105 lathe.
    Configuration, iBOB2, AMD Gizmosphere1, PathPilot, Yaskawa 400W AC Servos, 6i25 - 7i77, +-10V analog control.
    Here are a few pictures. The 10" touch screen will not be part of the refit, only for testing touchscreen interface.
    I modified the Mitsubishi servo and motor power cables with new connectors for the Yaskawa servos.
    Iron-Man
    Attached Thumbnails Attached Thumbnails EMCO PC 105 PathPilot, iBOB2, Gizmosphere1, AC Servo Refit-emcopc105-jpg   EMCO PC 105 PathPilot, iBOB2, Gizmosphere1, AC Servo Refit-emcopc105a-jpg   EMCO PC 105 PathPilot, iBOB2, Gizmosphere1, AC Servo Refit-icon-jpg
    Jan 2009
    Default Re: EMCO PC 105 PathPilot, iBOB2, Gizmosphere1, AC Servo Refit
    EMCO PC 105 AC servo upgrade with Yaskawa 400W servo motors.
    Control is +- 10V industrial standard using iBOB2 + AMD Gizmosphere 1.
    An Allen Bradley VFD + SEW Eurodrive motor will be used to modify and test hal/ini files for the EMCO spindle motor.
    Iron-Man
