Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 01-06-2009, 06:43 PM
Mr. LocoMartin is on a distinguished road
Need help on a project.
Hello,
I am building a 1:8 scale live steam locomotive called a Heisler.
The left and right side frame pieces are suppose to be made up of a number of pieces silver soldered together.
I don't like that idea and afterwards you have to "adjust them" from all the heat warpage. I am going to make the side frames out of a single piece of CRS. I know this is going to be more stock removed than kept, but at least it will be straight.
I would like to have the frames wire EDM cut out from a single blank.
Here are the rough specs.
5/8" cold rolled steel.
.625 thick, 5.75 tall, 52.875 long.
You can go to www.212steam.blogspot.com and check out the screen shots of my blog to get an idea of what the frame is suppose to look like.
If anyone would be interested in doing this, let me know.
Thanks,
Martin
Old 01-07-2009, 10:38 AM
roysol is on a distinguished road
Cool project Martin.
The 52" length puts it outside the work area of most wire EDM's. It may be more suitable for plasma or water-jet cutting.
Cheers!
Roy Solomon
15-5PH Project 70 cdlenterprises General Metalwork Discussion 2 12-30-2008 02:04 PM
New Project Eric Brassard Hobby Discussion 8 08-30-2007 07:05 AM
DIY Project with MDF studysession DIY-CNC Router Table Machines 0 01-08-2007 02:57 PM
Look what I can do! (First CNC Project) cp8071 DIY-CNC Router Table Machines 7 09-06-2005 05:26 PM
Need a project DDM CNCzone Club House 0 08-27-2004 01:05 AM
