| EDM Machines Discuss EDM Machines here! |
#26
| Hi roswell28 yes, I think too that after changing the batteries I have lost parameter. I have tried many times to reload system. usually i use three tapes. One is erase, second is system 1 and third is system 2. fifth is e-pack. I do not know why there is not a fourth tape.did i missed the fourth tape.do you have dwc-90h. could you please tell me the parameters of system paramter. |
#27
Hi Buddy. I have just 3 floppy disk, one is for E-Packs,other for Pitch Error and the last one have the version of the software of the machine (It could be D1 or E4). Do you have the same disks? Do you have the right procedure to reload the software? If you need more help please let me know. |
#28
HI! I have four cassettes. As i have already told you that one is for erase and other two are for system load. One is for e-pack.I do not know where to find the machine software version? do you have dwc-90h? could you please send me the picture of your system parameter screen? I highly appreciate if you can. |
#30
| See attached: hopefully this is enough to get you going. Tech file is from FA20s If you get invalid epack number error then subtract 1280 from the shown epack number ie: 2051-1280=771 (E2051=E771) This is the epack difference between our FA and our CXs Hope this helps Last edited by Royster; 02-16-2010 at 07:47 AM. |
#32
| Rosweell28 >>> I have a 110HA model, maybe you could help me. i have the T215 code alarm, that says: "SECUENCE ERROR" this alarm becomes after a 10 min. aprox. working time , i re-start you know: FLUID > WIRE > MACHINING > START it works again about 3 min. and T215 again and again HELP ! |
#33
| We have a '98 FX10. On our machine the T215 error seems to be a generic error message. If you can be looking very carefully at the screen when the meesage comes on, it will very quickly flash a more specific error & then change to T215. That being said, I asked my dept forman about your issue. He said that they had a similar problem & it was simply the water level. The first time was when we just got the machine & the tech who set it up had only partially filled the holding tank, after a couple of weeks, the water evaporated a little & when we filled the tank, the water in the holding tank dropped below the sensor. My forman suggested checking water level, fiilters & perhaps clean the sensor in the tank. Good Luck |
#34
| Hello , I have four cassettes for FX30K. Are you still interested ? cassette 1 BRD-B00W005A1 (1/3) cassette 2 BRD-B00W005A1 (2/3) cassette 3 BRD-B00W005A1 (3/3) cassette 4 BRD-B19W050-A3 WEDM SYSTEM PROGRAM INGLISH cassette 5 BRD-B93W364-A0 DATA I/O cassette 6 PITCH ERROR AND BACK LASH cassette 7 BRD-B13W019-A6 E-PACK |
| Problem- Mitsubishi Wire EDM | Roswell28 | Esprit | 1 | 12-04-2008 10:14 AM |
| Mitsubishi FX1 Wire | one4design | EDM Machines | 3 | 10-05-2008 01:37 PM |
| Mitsubishi FA Series Wire EDM | supercrewed | EDM Machines | 6 | 08-20-2008 09:21 AM |
| Mitsubishi Wire EDM ---Solenoid...... | THScout | CNC Plasma and Waterjet Machines | 1 | 04-08-2008 04:27 PM |
| Mitsubishi, DWC-110G Wire EDM | professor | CNC Plasma and Waterjet Machines | 1 | 03-02-2008 02:56 PM |
