Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 09-26-2008, 10:11 AM
debadip.basu is on a distinguished road
Problem in FANUC Wire Cut Machine
Hi Everybody,
This is my first post,I am having problem in FANUC make Wire Cut machine of Model-P,
System-6M model -B
Machine works ok in manual mode,no problem in referencing also.
But in auto mode it works up to the blocks having G0 command.
After reading the G01 command in any block it stops at that point only.
Even sometimes it works in that block also.But mostly for few days it stops at that block where G01 is given.
Checked the parameters,found OK.Make memory clear operation and tried but same problem.
Need help !!!!!
Debadip
Old 09-27-2008, 12:59 PM
gabedrummin is on a distinguished road
When it stops what error code dose it give ....have you tried to re -inatialize the bubble memory.....???
Old 10-04-2008, 05:30 AM
Reinitialize
No, there is no alarm .
Yes I have tried to reinitialise and found the same problem.
Regards
Old 10-30-2009, 10:28 AM
flextech is on a distinguished road
Unhappy i´v got the same error
Hello
i`v got exactly the same problem have done almost everything i could
anybody got a clue where the error is
the machine is a fanuc model-H and dryrun, G00 works perfect but when i set G01 it just stops on that line i had an service man here but he couldent
findout the reason no alarms or error codes shows
Old 11-04-2009, 05:03 PM
Medm's Avatar
Medm is on a distinguished road
This may sound like a stupid question, but are you using a G94 on the G01 with no feed value?
Old 10-08-2010, 12:05 PM
dbarr is on a distinguished road
I am having same problem with my tape cut W-1 did you guys figure out the problem?
Old 10-12-2010, 02:25 PM
wdevine is on a distinguished road
Another possibly stupid question, but (on a couple of my Fanucs, at least) are the 4 conditions on? The old Fanucs won't turn them on automatically without an M86 in the program, or you manually turn on the wire feed, flush, tension, and spark.
Old 10-25-2010, 02:00 PM
EDM_Fixer is on a distinguished road
Set your machine up for a simple MDI move.
MDI
MDI Next page.
input any safe move. x1.y1. input.
push dry run
feed rate override "0"
Press Cycle Start
Machine should drop the move into auto
turn up feed override some... it should move.
feed override back to "0"
press Feed Hold
turn off dry run
turn on the 4 functions
Wire
Water
Tension
Power
Hope your little lights work in the switch...
Press cycle start again.
If it kicks out there. More often than not the wire break switchs are not made.
You can check them in the diagnostics section. ( if you cant find um let me know and Ill get you there.)
But if the machine kicks out of cycle there (above) then one of the 4 functions required for burn cycle are not being met.
GL Jim
Old 12-11-2010, 11:05 AM
dzcatic is on a distinguished road
problem on wire machine
hi
I have wire machine, type: Fanuc Matra
When machine should start cutting i got reverse control alarm. I think that I got the alarm because when I turn on generator voltage don't increase.
does anyone have an idea what is this problem about, and how to fix it?
Old 12-11-2010, 11:24 AM
When you put it in cycle.
( With the 4 functions. Wire, Water, Tension, Power on.)
Does the meter (the one with V) show 90 to 110 volts? Does it jump up before the cycle is kicked out?
  #11   Ban this user!
Old 12-11-2010, 11:29 AM
no it doesn't jump up before the cycle is kicked out. the meter that shows voltage doesn't increase, maybe that is the reason why i got reverse control alarm
  #12   Ban this user!
Old 12-11-2010, 12:22 PM
Does your machine have a wire break light? A lot of times there are lights bunt out on front panel makes it hard to be sure the 4 functions are on.
If so. Then make sure the wire break switches are working.
That said; In the back on the bottom of the cabinet there is a big transformer looking thing. Thats your DC generator. On top in the middle you will see a terminal strip w/2 wires. (Those 2 wires go to the starter mounted on the right. Thats the starter that makes the click you here when you turn the power on.) Clip in a meter set at DC there. As you change your voltages on the front the output here will change. There will only be 3 I think. ? 90-100-110 VDC? There about.
Mitsubishi DWC-110H A Wire EDM Floppy Problem tjurek Machine Problems, Solutions , Wireless DNC, serial port 5 10-11-2007 08:08 AM
Fanuc 15ma - Kafo milling machine problem! F.Sharifi Fanuc 6 06-09-2007 02:58 PM
Problem with Brother Wire EDM JINX222 CNC Plasma and Waterjet Machines 2 03-11-2007 01:29 PM
Mits FX2 Wire EDM Problem. weblogictech CNC Plasma and Waterjet Machines 1 12-16-2006 01:28 AM
Mitsubishi H110 Wedm Wire Problem osomaker CNC Plasma and Waterjet Machines 1 12-11-2006 01:23 PM
