Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 08-07-2008, 04:42 PM
shazam/TPP is on a distinguished road
replace CRT on charmille roboform 20
hello to all, this my first post here so please be gentle
has anyone tried to replace their old CRT on charmille roboform 20 with a flat screen LCD? i've heard you can do this but not sure as to what's needed.
going thru charmilles is big $$$$$.
Old 08-09-2008, 06:11 AM
gridley51 is on a distinguished road
Not familiar with Charmilles but it should be possible to replace the monitor.I have a very good tv repairman who can normally fix my monitors very cheaply.For info on replacing with an lcd do a search of the PM website.Don Thomas who runs the site has done a lot of work on this and has posted a lot of very good info in several threads.
Mark.
Old 08-09-2008, 07:21 AM
Thanks Mark
Old 08-09-2008, 09:09 AM
Mark,
where is this pm website? i can't find the link here maybe i'm blind.
Old 08-10-2008, 08:31 AM
mdynac's Avatar
mdynac is on a distinguished road
Originally Posted by shazam/TPP View Post
Mark,
i think he means "practical machinist"...but i may be wrong, albiet a good source of info....
Registered Linux User #348337
EMC2 Rocks!!!!
Old 08-10-2008, 09:42 AM
Here`s a link to one of the discussions.
http://www.cnczone.com/vb...ghlight=screen
Mark
Old 08-12-2008, 12:19 PM
thanks again Mark, alot of useful info there. hopefully it'll solve my problem
Old 08-12-2008, 03:31 PM
budP's Avatar
budP is on a distinguished road
Go to where all the brains go anandtec.com
budP
Old 08-20-2008, 10:14 AM
nastek is on a distinguished road
you can replace with analog vga monitor, charmilles have 2 VGA ports.
1 port is same with VGA standart
Old 08-09-2009, 08:06 PM
WIRE CUTTER is on a distinguished road
You have to look at your connector in order to help determine possible stardards. If it is CGA or EGA you may consider buying an EGA or CGA to VGA converter card. Google EGA to VGA converter and you will find alternatives.
  #11   Ban this user!
Old 08-14-2009, 01:16 AM
doc0302 is on a distinguished road
WE HAVE REPLACED THE CRT ON ROBOFORM 30 WITH AN LCD , JUST PLUG AND PLAY . THE ORIGINAL MONITOR WAS A VGA CRT.
  #12   Ban this user!
Old 08-25-2009, 12:40 AM
titan99 is on a distinguished road
CRT to LCD
Yes, it is possible.
Few months before we have changed CRT to new LCD. If you want to confirm, just plug the cable into the LCD to see whether it is accepting it or not.
As a word of caution, some times the CRT, while dying, may bring down or fuse the mother board too. Then even though you change the monitor, you cannot see any thing. And some times the bit rate or baud rate may not match and hence you may have to tweak the BIOS of the machine.
Try yourself first and if it doesn't works, call CT.
My 2 cents.
http://www.titanengg.com.sg
Titan Engineering, Singapore. Titanium Metal & Alloy suppliers.
Roboform 35 Software Wilsonville EDM Machines 1 08-02-2008 09:36 AM
E32 encoder replace tech5028 CNC Swiss Screw Machines 2 06-24-2008 05:31 AM
hurco will replace electromech HURCO 0 04-13-2008 05:54 AM
Charmille Roboform 200 ErnieD Moldmaking 0 04-10-2007 09:46 PM
charmille wire guides radavis321 CNC Plasma and Waterjet Machines 1 02-08-2007 11:43 AM
