| EDM Machines Discuss EDM Machines here! |
| Old junk Makino Wire Cut I had an opportunity to own two set junk of Makino EDM wire cut, but not sure what will I do with them. Looks like all the junk still have the most of the parts. Here is the list: - Two set of Main unit - Two set of Makino MGW-15 Controller - Two set of Fanuc 200C Controller - Two set of Display Unit for Fanuc Controller - Two set of Pump unit - Two set of Filter unit I had No Experience with this kind of machine before, need some advice here: - What is the type / number of this machine? - Why do they have two kind of controller (Makino MGW-15 & Fanuc 200C)? - Where to find any documentation of them? - Possible to rebuild? - How about retrofitting (with mach3 for example)? They have Fanuc DC Servo Motor on the main unit. TIA, Ichan. |
| as long as the machines have a manual generator, you should upgrade to EMC2, the "adaptive feedrate" function will work for edm servo loop control.
__________________ Registered Linux User #348337 EMC2 Rocks!!!! |
| Thanks, just downloaded the EMC2 Live CD - will need some time to dig into it before i can ask more. So Mach3 can't do that? My understanding about the adaptive feedrate, it is to maintain the gap between the wire and the workpiece, how it works? If EMC2 adjust the feedrate based on some feedback, then what kind of feedback? How to know if the machine has "manual generator" or not? Sorry for dumb questions. BTW, there is a small name plate on the back of the machine covered by paint, after soft sanding the number appears, it's a Makino EC-3040... -ichan |
| wht kind of feedback? gap voltage feedback,. all wire edms use this, just find the wiring and the circuit, and pick a logical place to feed to adaptive feedrarate input of EMC2, which would be an A/D convertor input, I used a Motenc Lite card for axis drive and i/o google motenc how to tell if it is a manual generator, well, er, do you adjust knobs attached to switches, or are your generator settings input via a computer(GUI) ? the 3040 is a manual generator.....i remember those machines, a perfect candidate for EMC2...... hope that helps
__________________ Registered Linux User #348337 EMC2 Rocks!!!! Last edited by mdynac; 08-10-2008 at 08:19 AM. Reason: added more info.....and removed/added typos, as usual.... |
| New Machine Build- junk box precision mill | KTP | Benchtop Machines | 2 | 04-28-2008 09:25 PM |
| Journeyman 320- convert or junk it? | Tom Curran | Tree | 1 | 12-11-2007 12:55 PM |
| Junk foam CNC? | ls7corvete | DIY-CNC Router Table Machines | 23 | 03-15-2007 11:29 AM |
| Junk Physics | flakker | Benchtop Machines | 8 | 10-21-2006 07:43 AM |
| Help to identify another piece o junk again. | Konstantin | General Electronics Discussion | 13 | 09-25-2004 01:12 PM |
