| EDM Machines Discuss EDM Machines here! |
We have a Sodick EDM model A7C with MARK X1B contol. The machine was kept idle for few months. When it is made on now, it is booting ok. But, when trying to do zero return, the axis does not move and gives various error messages like Heat stop by overload press ack key, Touching limit switch on stroke end (over travel ) press ACK, etc. When I press ACK key, the error does not go. I want to know, whether this problem can be due to parameter loss. Can anybody provide parameter settings for this control ? |
| Even manually also can not move axis. The same type of errors come and it can not be reset. When I do zero return, the error comes, but the particular axis display keeps counting, eventhough the particular axis is not physically moving. We do not have any user's manual for this machine. |
| try this, source up machine, then power on now see if you can push an axis, i know, i know th A7C is a huge machine, but try anyway....if you can move the axis by pushing on it, then you are not getting power to the servo motors, start checking the servo drives, power supply, fuses, etc..... i do not think that parameters (or the lack of) would keep the machine from doing a simple jog......i may be wrong tho... also, i should mention that since the machine sat for a few months, maybe there actually is a heat stop occurring, so check to see that the axis move freely and they are not sitting on a limit. and check the leadscrew oiler........ hope this helps
__________________ Registered Linux User #348337 EMC2 Rocks!!!! |
| check the battery on the cpu board in the nc rack
| Thanks for your information. The voltage of the battery located in CPU board shows 3.64 V, which seems to be ok. Whenever I power on to PC, It either asks 'how many files (0 - 15)?' or 'No system files'. System and user floppies are already loaded to the respective floppy drives. Whether this problem can be due to system floppy not good ? |
| get me the software version and the machine serial number and i will see what i can do about getting the boot disk for you. I have seen these machines act up from the batteries being bad. I work manily on the mark25 controls and up but i can can ask the older service people about this issue. |
| Lirtex CNC Machine, model 2008 | lirtex | DIY-CNC Router Table Machines | 0 | 06-16-2008 02:01 PM |
| Sodick Mark X1B EDM Machine | rajappa | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 10-23-2007 10:56 AM |
| Older Model Fanuc Control | Freddy4 | Fanuc | 1 | 06-18-2007 06:41 AM |
| anyone can machine this model? | designhawk | ArtCam Pro | 7 | 06-02-2006 03:09 PM |
| Bridgeport CNC Mill, Model R2E4, Boss 9 Control | Tbucit | Bridgeport and Hardinge Mills | 5 | 03-17-2006 10:39 PM |
