Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 11-14-2007, 01:58 PM
Larry B. is on a distinguished road
Wire EDM after Black Anodizing
Can you wire cut Aluminum after Black Anodizing? I have to do a .0629 +.0002/-0.0000 and can not control the size prior to Anodizing. I have been told before (I think) that you can't wire edm after Anodizing unless you strip the area to be cut, and even then it will discolor the finish. Any suggestions?
Old 11-08-2008, 02:21 AM
wire_edm is on a distinguished road
Cut the hole first and then the hole can be plugged during anodizing. If the hole tolerance is held tight to the edges or other features you will need to comp for that during pick-up.
How to tell the difference in Black ABS VS Black Delrin? conceptmachinin General Material Machining Solutions 5 10-17-2011 10:43 AM
anodizing pyroracing85 General Material Machining Solutions 17 02-27-2008 12:22 AM
RFQ anodizing bucont Employment Opportunity 4 03-22-2007 03:14 PM
Anodizing? Klox General Metalwork Discussion 16 05-03-2005 01:46 PM
