Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 10-15-2003, 09:49 AM
Wjman's Avatar
Wjman is on a distinguished road
Wire edming PCD
Help!
we have been offered a large contract to wire EDM pcd, we've never cut anything like this before, but we know companies that do. Our machines are Hitachis, none are submerged.
Does anyone have any suggestions as regards power settings etc, we've tried a few settings without much success. We are pretty sure we can do it, but could do with some pointers.
Thanks in advance Mark...
If in doubt ask!
Old 10-15-2003, 01:59 PM
Klox's Avatar
Gold Member
Klox is on a distinguished road
What's pcd?
Klox
*** KloX ***
I'm lazy, I'm only "sparking" when the EDM is running....
Old 10-15-2003, 02:30 PM
Reto is on a distinguished road
PCD
PCD=polycrystalline diamond
Old 10-16-2003, 12:50 PM
Klox's Avatar
Gold Member
Wjman,
I did not know that these stuff could be wire-edm. Where are PCD used in the industry? Please fill us in on this topic.
Klox
*** KloX ***
Old 10-16-2003, 01:36 PM
Wjman's Avatar
PCD
Klox,
PCD or polycrystalline diamond is used for cutting tools, that have to cut very hard materials, ie rock or more commonly hardened steel, we use PCD tipped inserts on our lathe to turn hardened metals. I'm sure that's just the tip of the iceberg, maybe someone else can elaborate more. The PCD we are trying to cut is bonded to Tungsten carbide and they are removable inserts for a rock drill. BTW I've sent "chikara" an e-mail.
Talk to you soon Mark...
If in doubt ask!
Old 10-16-2003, 10:47 PM
CAMmando's Avatar
CAMmando is on a distinguished road
PCD blanks usualy have a tungsten backing or substrate that supports the diamond. The diamond is sintered with cobalt which is what actually is eroded in the edm process. The wire actually travels around the diamond crystals. So the process is dependant on several factors. The grade of diamond (cobalt content, crystal size). The generator on the machine.
How well does your machine cut carbide ? This may be an indication.
I think you are going to have to do some test cutting if you have an older unsubmerged machine and dont have tech support or existing technology files.
If your machine cuts it without excessive wirebreaks, rest assured the cut speed will be slow.
Wee aim to please ... You aim to ... PLEASE.
Old 10-17-2003, 02:46 AM
Klox's Avatar
Gold Member
CAMmando,
The older edm machines with DC generators normally "battle" to cut materials (non ferrous alloys) out of the ordinary. For example you get discolouration when cutting tungsten & Ti. The newer AC generators cuts faster & better! I have read about "intelligent arcing adjustment" on new edm machines that keeps generator settings optimal and prevents the electrode from shorting out. Some machines have Digital dual voltage (high/low voltage). The current being synchronously discharged to ensure faster material removal rate, uniform suface finish & lower electrode wear.
I haven't come across PCD, if i have to cut it i would start out for settings for Ti/ tungsten and play around..........
Klox
*** KloX ***
Old 10-17-2003, 02:50 AM
Wjman's Avatar
PCD
Thanks CAMmando,
I know about the sintering process, our machines cut carbide quite well, so perhaps that's the approach ie using carbide settings.
Thanks again Mark...
If in doubt ask!
Old 10-17-2003, 02:57 AM
Wjman's Avatar
Thumbs up PCB
Thank you also Klox,
Our replies crossed, our newest machine has an AC generator (still an unsubmerged machine though). I will try the carbide settings and let you know, cause I know you also have a Hitachi machine.
If in doubt ask!
Old 01-23-2008, 03:09 PM
K&Y's Avatar
K&Y K&Y is offline
K&Y is on a distinguished road
Originally Posted by Wjman View Post
Klox,
Wjman, in actuality , CBN (Cubic Boron Nitride) is used to turn hardened metals (best results are seen when used on materials over 45 RC), whereas PCD (Polycrystalline) is used to non-ferrous applications (aluminum alloys, copper alloys, metal matric composites, hard plastics, carbon-fibre, sintered tungsten carbide, and precious metals).
I hope that this will clear up any confusion as to where PCD and CBN tools can be applied.
K&Y Diamond Ltd. - Ph:(514) 333-5606, Fax:(514) 339-5493
http://www.kydiamond.ca
  #11   Ban this user!
Old 01-23-2008, 04:23 PM
mdynac's Avatar
mdynac is on a distinguished road
you need a high voltage setting, like over 200 vdc
try some copper underneath the pcd....(well clamped)
Registered Linux User #348337
EMC2 Rocks!!!!
  #12   Ban this user!
Old 01-29-2008, 11:01 PM
sodickappsguy is on a distinguished road
i use modified carbide settings cause you are basically cutting the bonding agent not the diamond. The settings are still kinda black magic cause you settings and finish depends on what size the diamonds the MFG is using. Micro fractures can happen just like in carbide. Oilfields love pcd and woodworking plants use pcd over carbide cause of the tool life.
4 Axis Wire EDM Application squarewave CamSoft Products 4 09-30-2008 11:18 AM
Motor controller development for laser owhite Laser Engraving & Cutting Machines 21 06-25-2008 07:10 AM
ONA Wire EDM Wilkerson CNC Plasma and Waterjet Machines 6 07-03-2007 06:48 AM
Wire EDM show and tell Graham S CNC Plasma and Waterjet Machines 5 01-21-2005 04:17 AM
Correct Stepper Wire ? ? Mr.Chips Xylotex 1 05-08-2004 09:44 AM
