Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
  #13   Ban this user!
Old 02-10-2008, 04:33 AM
mdynac's Avatar
mdynac is on a distinguished road
if you want to cut pcd or cbn, get and old andrew ef (biege)series machine,
it is the defacto standard for cutting diamond.......hands down.
i can modify them with a new pc based cnc system, instead of the old pdp8.
i have 6 customers whose ONLY business is pcd and cbn cutting, and they have about 40 andrew ef's between them doing this job.
these machines can be had for as low as few hundred bucks, and edm network has full support on them.
the old agie 312(?) machines work excellent for this also.
these machines cut pcd/cbn without any modification at all, they cut it like soft butter.
Registered Linux User #348337
EMC2 Rocks!!!!
  #14   Ban this user!
Old 11-08-2008, 01:18 AM
wire_edm is on a distinguished road
If a grade of PCD can be used with a smaller grain size this should be easier to cut and have better geometry. I am currently cutting with .004 wire and if needed to a finish of 7 to 8 ra. Have had trouble when cutting small radii (ex .0008 r).
4 Axis Wire EDM Application squarewave CamSoft Products 4 09-30-2008 10:18 AM
Motor controller development for laser owhite Laser Engraving & Cutting Machines 21 06-25-2008 06:10 AM
ONA Wire EDM Wilkerson CNC Plasma and Waterjet Machines 6 07-03-2007 05:48 AM
Wire EDM show and tell Graham S CNC Plasma and Waterjet Machines 5 01-21-2005 03:17 AM
Correct Stepper Wire ? ? Mr.Chips Xylotex 1 05-08-2004 08:44 AM
