| EDM Machines Discuss EDM Machines here! |
Looking for error codes for my chiller? have alarm codes for my machine but nothing for the chiller. Just got my machine hook back up after a year of not running everything worked fine before then but the chiller is having issue now. The error is C3 and then one other one is E1 and that one brought up a u827 on the machine. I just like to find out the codes are so I can fix this thing. Thanks for any help. |
| If I remember correctly a C3 is freezing (try touching the elbow joint somewhere around the base of the chiller. (it should feel very cold) and an E1 is "cannot keep temp difference at 5F or below from room temp" - ie: room=18C deg machine water=24C deg and climbing We shorted out 2 links in one of our machines which fools your machine into thinking the chiller unit is A-OK! Usually your chiller needs regassing or may even need the small capillaries inside the chiller replacing as they may be choked up Let me know if you need more info |
| Royster How do you short out the two links on the chiller or machine so it will stay running? I have a guy that is going to try to charge the system. The chiller has never been serviced and it was new in 98. The c3 code comes up when it is at idle. but the E1 comes on when it is cutting. The one day it never come on and the next day it will come on at 3-4 times a day if not more. I don't think it can keep up with the cooling? I know they sell aftermarket chiller for it that bypass the control too. there cheaper then the mits chillers and there are suppose to be better. They say the Mits chiller is there weak link? But it work since 98. hopefully it just needs a recharge! Last edited by sweet16; 01-05-2012 at 10:37 AM. |
| s&a cw-5200 chiller | curious | Laser Engraving & Cutting Machines | 12 | 12-04-2011 10:00 PM |
| what kind of chiller for an roboform 31 | blackdogmachine | EDM Machines | 0 | 08-26-2011 09:25 AM |
| Problem- Chinese Chiller | Dubliner | Laser Engraving & Cutting Machines | 8 | 10-06-2010 02:28 PM |
| Spindle Chiller Coolant | furnman487 | Fadal | 3 | 03-23-2006 05:16 PM |
| Mitubishi Dwc90c Error 500 | CHAD | CNC Plasma and Waterjet Machines | 10 | 01-15-2004 12:51 AM |
