Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 10-17-2011, 03:52 PM
Toolz is on a distinguished road
Cutting 20 deg. Taper in Mits FA20s
Having trouble with wire breakage on my Mits FA20S. I'm using Magacut T 500N/mm 71000 PSI. It is acting like the something is slipping but i can't seem to see that. As it starts to do a wire square it snaps before trying to do anything. Its starting to get on my last nerve. Any idears from anybody word be helpful.
Thanks Toolz
Old 10-20-2011, 06:29 AM
Royster is on a distinguished road
make sure you've got the larger holed nozzles fitted and remove the threading jet. Lower your WT a few notches and maybe the PT a little way. Lower the IP and SA raise the SB and VG. Finally check your lower roller bearings are good.
You may have a programme error whereby the UV are moving but the XY is dwelling thereby creating a situation that Mitsy Wirers aren't normally happy with. If so try tweaking your programme to keep XYUV motive
HTH
Lathe cutting a taper eartaker Mini Lathe 27 01-24-2011 12:45 AM
help with cutting a inverse taper angle redfoxbody11 General Metal Working Machines 12 11-12-2010 06:10 AM
Dainichi CNC lathe cutting taper grweldon General Metal Working Machines 1 05-30-2008 09:49 PM
Newbie- taper thread cutting cncmc Mazak, Mitsubishi, Mazatrol 4 05-05-2008 04:59 AM
cutting a taper on titanium rod marty7001 General Metalwork Discussion 4 07-20-2007 03:17 PM
