Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 10-04-2011, 09:03 PM
JohnWLMT's Avatar
JohnWLMT is on a distinguished road
Sodick AQ550 leaking.
We have an AQ550 that has a leaking tank. We have taken it apart and have replaced the tube and the seals along the plates that slide back and forth.
The problem is the plates have small cracks in the very thin surface material that runs along the rubber wipers.
Anyone figure out how to recondition these plates. Sodick wants $2800.00 for a set and 4-6 weeks delivery. Either way not very cool.
It looks like a thin sheet of lexan.
John
Air pressure regulator leaking Matt@RFR Haas Mills 5 10-22-2010 03:11 PM
Need Help!- FJV-250 Splindle leaking oil! Hastx Mazak, Mitsubishi, Mazatrol 3 05-29-2010 01:44 PM
SL-10 leaking like an old dog? shawncnelson Haas Lathes 1 11-05-2008 02:42 PM
Leaking coolant reservoir JTulley Tormach PCNC 5 08-03-2008 08:51 AM
Problem- thru spindle coolant leaking GARY DAVIS Fadal 4 03-25-2008 07:28 AM
