| EDM Machines Discuss EDM Machines here! |
I am thinking about starting this project as i have a spare edm machine and would like to convert it to a wirecut machine , I have disconnected the servo belt and the machine happily runs a electrode sideways ,The machine in question has already got ballscrews on x and y so all good there,I am thinking of running a stepper motor for the pinch roller so i can control wire speed from within the program or mach 3 ie; spindle speed,I have converted a mill to cnc before so familiar with that part ,Would be just x and y at this stage u and v maybe later So can you clever people see any major pitfalls ![]() Thanks in advance 1~ edm 50 amp with ball screws 2~ mach 3 full version 3~ cadx11 drawing package 4~ cambam g code 5~ Stepper motors for x and y 6~ Roll of .25m/m wire for starters |
| I made a wire head attachment to fit a Deckle 20 years ago. For about $1500.00 total. My wire was pulled through with a variable speed motor, I did not program the speed of the wire. I ran the wire horizontaly and use old carbide inserts for wire guides. So we programed it in Y and Z. Kind of ran like a big cheese slicer. You will need on and off times that are very fast or the wire will burn through. P.M. me and I will dig up what I have for paperwork and fax or copy and mail it to you.
__________________ Jetski (alias Tooling and Engineering Czar) "I may not have the keys to success.. but I have learned to pick the locks" |
| Jetski The reason i am using a stepper for the wire is i have one allready and the added bonus of speed control through mach3 , When it gets closer i may just go with a dc motor and variable speed ,, Carbide guides sounds interesting did you spark a wire hole in them ? ,, Thanks for your reply i will PM my email address ,fax number if you could find any info on your conversion would be appreciated regards Bernie |
| i agree with jetski. your going to have to examine the output pulses of that sinker genrator. a wire machine's generator output is not quite the same as a sinker generator. the "ON" times may be too long. the pulse generator may need to be modified as it may not produce short enough ON times as is. just some thoughts what brand and model generator????
__________________ Registered Linux User #348337 EMC2 Rocks!!!! |
| The edm i will be converting is a Hostek SH310p 50 amp machine , I will examine the settings for on and off times when i get back to the workshop,, Do you know roughly what on/off times i should be looking for Bernie |
| PULSE RATE (frequency) adjustment may be a problem with the sinker gen. usually there is no provision for that as they adjust OFF time instead. the pulse rates should be variable from approx. 5Khz to 55Khz ON time variable from like 1 uS to 3 uS use 250 nS increments. so you will have like 12 ON time selections. OFF times would be all the rest of the time in relation to 1 second minus the rate and width of the ON time. so you would really, really, really like to have the following in you wire machine generator: variable PULSE RATE variable ON TIME don't get me wrong, the sinker may generator work as is, kinda.......... or it may just break wire all day. you also need to generate consistent tension on the wire and also smooth consistent wire feed system. good luck.
| Okay just been looking at the manual for this machine and it has variable on times of 1us to 999us and it looks like the off time is a percentage of the on time from 1 to 9 ,So i will just have to try it and see how it goes i will get back ,I am building the head at the moment then i will try it cutting steel in a manual feed as the cnc part is the easy bit Bernie |
I had thought of an idea many years ago if you did not have a pulse generator. Could you take and make a 10 lobe cam and put a set of points on it like the way a motor use to work and run the power through the points and the cam on a variable speed motor geard up or down as needed. The points would open and close and send the voltage to the wire. Or in todays world you could use a solid state relay to pick up and send the voltage picking up on the high spots on the cam or set screw sticking out of the pully. The motor could be variable speed AC or DC and not have to have much torque. You could have several pullys with several different screw configurations (2, 4, 8, 10, 12, ect). To make more pulses per revolution. Just an idea. Take it for what it is worth.
#10
| Hey are you making fun of my cell phone? I am out of Northern Indiana and well my phone carrier is Amish Bell, And I don't get good signal till I pull the string tight and can actually see Yoder. I have the only Cell phone with a party line, (you'll have to be old to get that joke Graber). Sometimes I have these wild dreams...Like I am going 2 times the speed of horse! Hey I got to go and shut down the generator the Parson is headed toward our lane. Talk to all of you later. Be radical wear your Amish hat backwards, and make them call you Jeb Daddy.
#11
| Okay ive been snapping wire all week , Can anyone give me a starting point for the settings iam cutting a piece of p20 tool steel 15m/m thick ,It works but i have to have the settings very low otherwise the wire breaks, These settings are as high as i can get , It is very slow like .5m/m in 10min Current 2 amps on time 200us off time around 50% of on time PS : I remember party lines you would pick the phone up and hear a voice then would have to wait untill they finished to make a call,, ahhh good old days Bernie |
#12
| you should read the info supplied above and you will see that the your ON time is WAY too long and your OFF time is WAY too short. what about your wirefeed system and wire tension BOTH must be smooth and consistant or you break wire? what about the flushing????? how are you doing it???? pictures please!!!!!
| Brother HS-300 Wirecut EDM | contour | EDM Machines | 3 | 04-13-2012 05:52 PM |
| Looking for a wirecut melbourne | bjay | Australia, New Zealand Club house | 0 | 09-24-2011 05:59 AM |
| CHMER wirecut parameter | john s | EDM Machines | 0 | 03-08-2011 02:01 AM |
| DIY EDM Wirecut + Sinker | franzschluter | EDM Machines | 10 | 09-10-2010 02:22 AM |
| Wirecut Machine | Ashish B | EDM Machines | 1 | 08-18-2009 02:51 PM |
