Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 08-15-2011, 12:44 PM
gabedrummin is on a distinguished road
Burn Carbide
What would you charge to burn out a carbide plug .530 diameter .625 deep..?Needs to be completley removed , without burning existing walls....? THKS
Old 09-14-2011, 03:28 PM
limet43 is on a distinguished road
Burn plug out
Is the plug solid?, we have a hole popper if so, need some more information though as to the dimensions of what the plug is in and also a picture if possible. I need to know how to fixture it first before I can quote a price.
Regards,
Dave
Old 09-21-2011, 09:09 AM
moldman3 is on a distinguished road
ARE U
ARE U GABE THAT LIVED IN EL PASO?
Old 09-21-2011, 01:21 PM
Yes I am , George whats up...? Burned some carbide out and I think I was too cheap took 4 hours each.....
Old 11-20-2011, 01:19 PM
Wire-EDM-Guy is on a distinguished road
We usually aim for $50-$60 an hour.
Old 11-20-2011, 02:10 PM
Smile carbide
thanks but i think gabedrummin was asking
Old 11-23-2011, 06:31 AM
Plug was solid with a domed head , and was in the end of a drill head , had to clamp head to angle plate mounted to a sine plate and burn out carbide without touching sides , as plug is pressed in and when chiped one is removed a new one is pressed in . I did the job for 60.00 each and took 4 hours on one and took 6 hours on the other. Did two.
Old 11-23-2011, 08:38 AM
carbide
Gabe were are you living these days?
HAVE A HAPPY TURKEY DAY!
Old 11-23-2011, 02:07 PM
Spring Tx. About 30 miles north of Houston Tx.......915-252-6111. You all have a great Thanksgiving also...!
Colombo burn out Paul Petersen Commercial CNC Wood Routers 0 12-28-2007 01:16 PM
Resister Burn wanchai101 Fanuc 1 06-22-2007 04:06 PM
R Shunt Burn wanchai101 Servo Motors and Drives 0 03-26-2007 10:20 AM
burn owhite Laser Engraving & Cutting Machines 8 12-17-2005 02:17 AM
Why do I burn my hand? ESjaavik General Metalwork Discussion 7 06-15-2004 06:48 PM
