Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 04-05-2011, 03:19 AM
Ashish B's Avatar
Ashish B is on a distinguished road
Post Does CNC EDM do Sparking in X & Y axis ?
Hello,
I know that normally EDM Operation is done in Z axis. But i was curious to know that does CNC Spark EDM Machine do Sparking in X or Y axis ?
Ash
Old 04-05-2011, 04:41 AM
Royster is on a distinguished road
Simply, yes it does in both Positive and Negative senses too.
More indepth they also can work in polar coords too (ie XYZ and C rotation all moving) Imagine trying to machine a spiral hole!
Old 04-05-2011, 07:56 AM
Ashish B's Avatar
Really Gr8 to hear about that spiral machining feasibility on a EDM.
Thanks for your wonderful respone.
Bye. Tc
Old 04-05-2011, 10:06 AM
Thanks and you're welcome.
Problem- Laser machine sparking/arcing what went wrong? c02laser Laser Engraving & Cutting Machines 10 11-08-2010 12:38 AM
Noob Q: Sparking out broken Carbide Wheelz EDM Machines 0 08-20-2009 10:54 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 01:54 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
