Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 03-10-2011, 10:51 AM
colorada is on a distinguished road
Exclamation Agie PDR -33C Board Problem
I have an Agie 100D Wire EDM machine.The Control unit is an AgieMatic CD.
The Generator unit is an AgiePuls MMDI have a PRD-33C and a PRD-34A board set.I have an error message of :
"Agiepuls MMD not in Start" with only one Message 511.
The best I can understand is the PDR-33C board has something bad on it because it will not put power through to the wire for erosion. It will fill the tank, start up the operation and roll wire but then it sits still until it faults with the 511 message. Before it faults out the AgiepulsMMD unit does turn on the GL1 light but faults out before the GL2 lights up.
Do you know where I can buy another PRD33C board or where to get it repaired or traded out?
Sorry for the long message I just wanted to give as much information as I had from the start.
Thanks for your help.
Old 03-30-2011, 11:06 AM
That is now fixed. Now I have to find a mastercam post for this agie 100d machine in inches
Tags
agie100d, agiepuls mmd, prd-33c
board problem visky UHU Servo Controllers 1 01-03-2011 02:55 AM
Agie Progress 2 - problem running 'lights out' Kevinoh EDM Machines 1 12-04-2010 07:47 AM
Odd problem with c10 BO board binfordw Benchtop Machines 3 01-23-2010 02:02 PM
problem with ram board diegobertoli Fanuc 0 01-30-2009 02:11 PM
I/O board problem squarewave CamSoft Products 16 10-28-2004 11:00 PM
