Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 02-28-2011, 01:04 AM
Ashish B's Avatar
Ashish B is on a distinguished road
Ovality achieved By electrode
Hello ,
If I EDM a electrode of Dia 3 mm into a Part, how much ovality should I get in that hole.
..Actually its a bearing surface & hence the required ovality should be within 0.005 mm
Also apart from doing EDM Operation in Z axis, does EDM MACHINE do EDM operation in X and Y axis ?
.. Actually I want the ID hole & OD hole operation to be done in single setup so that perpendicularity is within 0.005 mm.
Ashish
Reamed Hole ovality Ramu CNC Machining Centers 1 04-04-2010 09:07 AM
A Milestone Achieved whitehedr Benchtop Machines 5 12-09-2009 03:32 PM
Help with sinker edm electrode richrod EDM Machines 12 07-22-2009 07:55 AM
Ovality issues for aluminium parts Viru General Metalwork Discussion 7 04-04-2007 10:40 AM
Electrode Manufacture V HSM Tony the Ferret General CAM Discussion 0 12-07-2006 03:34 PM
