Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 01-28-2011, 10:01 PM
Ashish B's Avatar
Ashish B is on a distinguished road
How to grind Part of 3 mm ID
Hello,
I want to grind a Bearing ID of size ( ID is 3.00 mm ). Actually a shaft passes through it. The size & ovality accuracy is 5-10 microns.
The BIG question to me is how should I machine such Small ID.??
Some options -
=> WIRECUT - Can I wirecut such small ID on a Wirecut machine. Will i get the desired accuracy, size & ovality on a Wirecut Machine ?
=> REAMING - I tried reaming it, but it did not fetch the accuracy. I observed a ovality of 25 microns..
=> GRINDING - Is Grinding such small ID (on cylindrical Id grinding machine) possible ?
Ashish
Old 02-23-2011, 09:21 AM
Palisadetool is on a distinguished road
Ashish
How much material are you removing ? Honing might be the way to do this.
Old 02-24-2011, 09:47 PM
Ashish B's Avatar
Thanks for your reply.
I can predrill the hole upto any size to leave material for honning.
Is honning done on a drilling machine or a SPM is needed for it ?
Can honning give that desired amount of accuracy in terms of OVALITY ?
Ashish
Old 02-25-2011, 03:41 AM
Honing
In a "drill press" it is referred to as Lapping basically the same type of metal removal just not as accurate. A lot of guess work as to when it's finished. Getting it honed with a honing machine (sunnen) it is much more accurate and your concentric run will be more true as the size and finish will be more of what you are looking for. Either way you want to leave only a few Thousandths of an inch (.005) to clean up while you should start out with a good finish after drilling. If you wired it out true you will only have to leave perhaps .002 and the finish hone will go better then twice as fast.
Hope this helps
regards
Palisadetool
Last edited by Palisadetool; 02-25-2011 at 03:55 AM. Reason: added more informatin
Old 02-25-2011, 07:26 AM
Ashish B's Avatar
But is honing such a small ID (3 mm) possible?
Old 02-25-2011, 07:41 AM
Yes I believe it is. Talk to Sunnen.
Old 02-26-2011, 09:58 PM
Ashish B's Avatar
Really thanks GENTLEMEN.....
I was very very much concerned about Machining such Small ID. The whole project was on stake because of this ID Machining operation.
Thanks, ONCE AGAIN
Ashish
Need Help!- How to grind shaft of 2.0 mm diameter Ashish B General Metal Working Machines 32 01-02-2011 01:06 PM
Newbie- HMC CNC to grind HSS plate davidscott General Metal Working Machines 2 03-29-2010 05:38 PM
Does anybody grind their own endmills in house? ryanschmidt224 General Metalwork Discussion 1 02-22-2010 01:23 PM
surface grind gibs? phantomcow2 General Metal Working Machines 0 06-11-2006 07:10 PM
Grind my bearings? Oldmanandhistoy Linear and Rotary Motion 20 02-18-2006 07:53 AM
