Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 01-21-2011, 09:28 AM
ehsan.amouzegar is on a distinguished road
Unhappy Sodick Wire BF 275
my bf275 doesnt move axises during M00 code execution! What should I do?
Old 01-21-2011, 09:31 AM
Unhappy Sodick BF 275
Ehsan.Amouzegar@gmail.com
Old 01-22-2011, 07:54 AM
LaserToolShop is on a distinguished road
M00 is a halt command, how did your command line written on your program?
Is the first time you use M00 command?
Old 01-22-2011, 11:49 AM
sodickappsguy is on a distinguished road
like said above the M00 is a hard stop in the program used to stop the machine so that you can remove slugs or move clamps to avoid crashes. When you reach the M00 you should be able to press the ENT button and the cut should continue. Is the issue that the machine will not restart after the M00?
SODICK WIRE EDM MARK 21 BKCOM EDM Machines 10 01-21-2011 09:53 AM
Sodick wire radius compensation rfarleman EDM Machines 6 12-07-2010 07:08 PM
Sodick Wire EDM Stiga EDM Machines 3 12-03-2010 06:21 AM
power supply size? for multi wire (total 250 inches of wire) DanOSB CNC Wire Foam Cutter Machines 5 03-02-2009 04:34 PM
New Sodick Wire EDM Machine (Affordability) AppliedMachine Product Announcements & Manufacturer News 0 01-11-2009 09:14 AM
