05-18-2011, 08:16 AM
Originally Posted by lfacio12 I've been trying to setup the cut monitor i that came with a Fanuc Robocut alpha-iC EDM. I'm having problems in finding out whether I need to connect my pc to a hub then from the hub to the edm? Any ideas? I cannot seem to make a connection straight from my pc to the edm through ethernet cable |
Where did you get the FANUC Cut Monitor i Software? We are running an Alpha-1iD. I was able to get it on our network. It was quite annoying that it wanted to use 192.168.1.1 by default. However I am unable to find this software to see if I can get a PC to connect to it. I cannot ping the IP I have assigned to it. Then again my experience with Windows CE is zero and I do not know how Windows CE handles ICMP packets via its TCP/IP stack.
I would appreciate any information.
Thank you. |
