Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 11-09-2010, 01:37 AM
*Registered*
coykiesaol is on a distinguished road
Wire EDM Aluminum?
Is there some special procedure you have to use for Aluminum? I have no epacks for Al. so in the dark. I'm kind of leaning towards it being something with the machine, if you hand jog the wire in .0001" increments, it cuts, but since I don't have any experience with Al. trying to find out if there could be something I'm missing to make sure I eliminate all the simple things it could be. Thank you so much for any input!
Old 11-09-2010, 02:27 AM
Royster is on a distinguished road
It would be useful to know what machine you have.
Epacks are just stored call outs that set your generator up for the task at hand.
I know on my Mitsubishis that I have to lower Ip a notch or 2 and raise VG by a handful (away from steel technology) to get aluminium to cut nice.
Wire EDM - Aluminum - Troubles greenchair EDM Machines 3 04-16-2010 06:53 AM
Running stepper motor wire with router wire? basskitcase DIY-CNC Router Table Machines 2 02-19-2010 10:18 AM
Cheap digitizing with aluminum foil and a piece of wire! cjjonesarmory Digitizing and Laser Digitizing 1 08-11-2009 03:15 AM
power supply size? for multi wire (total 250 inches of wire) DanOSB CNC Wire Foam Cutter Machines 5 03-02-2009 04:34 PM
How to wire an 8 wire stepper motor technosteve DIY-CNC Router Table Machines 1 01-16-2009 05:01 PM
