Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 10-30-2010, 03:05 AM
GtK GtK is offline
GtK is on a distinguished road
Fanuc Tape Cut W0 resistor
Just bought a Fanuc wire cutter. Problem: no EDM power.
Resistor R51 has blown out. It's placed between 2 connectors on top/at the right side of the discharging board (DSC PCB).
Because I cannot get an electrical scheme I hope someone can give me the colorcode on the resistor or send me a picture of the resistor.
Gert
Name:	Fanuc  resistor.jpg‎
ID:	117935   Click image for larger version
Name:	Fanuc view.jpg‎
Old 10-31-2010, 03:55 PM
mossy123 is on a distinguished road
Blown item.
Hi Gert,
Just sent you a private message then seen your pictures.
the blown item is turquoise in colour as with many.
look at bottom of board.
2 vertical black heat sinks, to the left of left heat sink 'R247' Value 100 micro Joules 3.
yours is physically this size with the 3 on the end but resistance is- 200 micro Joules.
hope this helps.
my machine was functioning well all weekend until reverse alarm repeated on skim cut and now EDM power button on front panel wont light or hold in?
chasing around for over loads and fuses but not sure which area to look as no schematics either!!!
Kind regards,
Chris.
Old 10-31-2010, 05:47 PM
GtK GtK is offline
Blown resistor
Hello Chris,
I first reacted on your private message and afterwards read the message "Blown item"
Thanks again for answering.
Because the fan of the U-V- axis unit was blocked by dirt (see picture) the resistor (electrical placed in line/decreases speed) was blown.
I checked the description you made and also my Farnell (Farnell / Electronic Component Distributors / Suppliers / Electronics, Electrical Parts, Electrical Components and Wholesale Electronics.) book. Specifications resistor R51: 200 Ohm, MOR series (J) 1Watt .
Best Regards
Gert
Name:	Fan U-V- axis unit.jpg‎
ID:	118060   Click image for larger version
Name:	Farnell resistors.jpg‎
Old 10-31-2010, 05:52 PM
Hi Gert,
please look back at my thread as i have just wrongly posted a reply to help you there with a picture.
Kind Regards,
Chris.
Old 11-01-2010, 03:08 AM
GtK GtK is offline
Hello Chris,
Just for information.
The J on the resistor stands for tolerance code and not as I mentioned for MOR series.
In this case 200 Ohm +/- 5%
The picture is clear.
Gert
Fanuc W2 Tape Cut Help!!!! Steve1982 EDM Machines 9 08-13-2010 07:34 AM
Fanuc power supply RESISTOR???? chonporting Want To Buy...Need help! 2 01-16-2010 07:46 AM
Fanuc Tape Cut EDM rmilaser EDM Machines 1 12-19-2009 02:24 PM
Fanuc Tape Drill O-MC Spindle Resistor Overheat?? John_B Fanuc 2 02-12-2009 06:59 PM
Fanuc tape mode mroy0404 Fanuc 2 03-17-2005 03:15 PM
