Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 10-07-2010, 08:00 AM
larswebb is on a distinguished road
Brass build up on cutting edge
I am having trouble with brass build up on my first cut. It makes removing the slug very difficult. Does anyone know what causes this?
Thank You,
larswebb
Sodick EPOC 300
Mark 11 Silver
Old 10-08-2010, 06:01 AM
I may have found a solution! I was using equal upper and lower flush pressure on 1" D-2. Now I'm using higher pressure on the lower guide, it seems to help. I also raised the upper guide to about .030 above the work piece. I'm learning this machine on my own with the aid of a old Sodick manual. Any help or advise would be greatly appreciated.
Thank you,
larswebb
Sodick EPOC 300
Mark 11 Silver
Old 10-12-2010, 01:30 PM
wdevine is on a distinguished road
I've had this happen when the conductivity of the water is way off, or if my ground or power cables are starting to go bad.
Old 10-12-2010, 01:39 PM
Royster is on a distinguished road
Agreed, we have a machine that has a broken lower power cable at the moment and we get it when we shove a good few handfuls of amps through a workpiece..
Old 10-20-2010, 05:01 AM
The conductivity is running about 10 and the cables have maybe 500 hrs on them. Is there a way to test cables? They look ok.
Sodick EPOC 300
Mark 11 Silver
Old 10-20-2010, 07:12 AM
dtrust is on a distinguished road
We have Mitz's here, but whenever we have the brass buildup problem it has always been either bad ground or power cables, as others have mentioned.
We've never been able to find a reliable test for the the cables. They check the same either new or old (bad).
You could try just removing the connections, cleaning them very well and reattaching them. A bad connection sometimes doesn't show much, but it's bad nonetheless.
Old 10-21-2010, 05:55 PM
*Registered*
TheBigJW is on a distinguished road
Sometimes on our Sodicks this happens when the conductivity pads are worn out. The carbide ones that send the power to the wire.
John
Just IN- New 5 Axis Water Jet Cutting Technology from Jet Edge Jetedge Product Announcements & Manufacturer News 1 09-17-2010 02:46 AM
strange edge when cutting acrylic zoefie Laser Engraving & Cutting Machines 12 08-23-2010 11:16 PM
Newbie- Cutting speed - Brass einarkol Benchtop Machines 2 11-20-2008 07:14 AM
Jet Edge Waterjet Cutting Demos at EASTEC 2008 Jetedge Product Announcements & Manufacturer News 0 04-16-2008 09:57 AM
Newbie- Rotozip cutting .02 brass... what bit? hualon General Metalwork Discussion 4 03-22-2008 03:52 AM
